Install the Edge Compute Platform App in the Device
- To install Edge Compute Platform App into the device, go to the Fleet Management section, choose your device (Raspberry pi 4) and open the Applications tab.
- Select the Edge Application from the first drop-down menu.
- Select the version to use in the second drop-down, and then select the deployment you just created.
To add the app, click Add.
Figure 1.The Overview tab will display the new pods. These pods correspond with the app just installed. The installation process may take time and may not display in the Applications tab immediately. To verify that the app is installed, just check if all the new pods are available.
