Edge Installation Using a Raspberry Pi
The goal of this process is to monitor and control your Edge Device remotely.
- Configure your Edge Device (a Raspberry Pi) with the correct OS system
- Learn how to access a Raspberry Pi through an SSH server
- Install the ECP Management Service to connect your Device to the Altair SmartWorks IoT platform
- Define your Asset on the Altair SmartWorks IoT platform
- Deploy the ECP (Edge Compute Platform) to your Asset
- Deploy code at the Edge to emulate data streaming
Requirements
- Raspberry Pi 4 with at least 4Gb of RAM.
- Power supply USB-C with at least 15w (5v and 3A).
- Micro SD card with 16Gb or more and an SD card or USB adapter in order to write the OS image.
- Monitor screen and a micro HDMI - HDMI cable if you want to use desktop functionalities. You could also use an SSH server in the Raspberry Pi.
- Keyboard and a mouse with USB for the first setup.
- Internet connection.
