This tutorial will guide you through the process of defining the digital representation of your physical asset (such
as a sensor) in the SmartWorks platform, sending data to store it, and developing simple, real time dashboards.
Stream Processing is a method of tracking and analyzing streams of information of an event, and eventually obtaining useful structured
conclusions out of that raw information.
SmartWorksEdgeOps is a set of tools for building, maintaining and continuously improving code in resource constrained devices at the
edge of smart connected ecosystems.
The Edge Compute Platform App isn't installed yet; you've only installed the
Management Service that enables you install the apps.
To make the applications available to be installed on your device, you need to add
them to your Space. The different applications available can be found in the
Marketplace section.
To install the ECP App or any other app needed, follow the next steps.
The first app to install is the Edge Compute Platform, named App -
Edge Compute Platform. Click on the box at the left of the name
and click Add to Space, positioned at the top right of
the web page.
The Edge Compute Platform app is added to your space. Figure 1.
Go to Edge Ops > Edge Applications.
You will see the app just installed, as in the following image: Figure 2.
Before creating a deployment of the Edge Compute Platform app, you need to
create a new App called Access Control. This will enable
the Edge Compute Platform app to interact with SmartWorks
cloud. To do that, click Access Control > Apps and click on the New App button at the top
right corner of the web page.
Complete the fields with your data:
Option
Name
Name of the new Access app. Suggested name would be
ECP or Edge Compute
Platform.
Description of this new App.
Scopes
Select category, mqtt,
space, and thing in
the drop-down list.
Select Client Credentials.
Click Save.
Your are directed to the Policies section.
When the App has been created, a Policy needs to be added to it. Policies
indicate what users are permitted to do. If you choose to add the role root
to this app (remember role root allows you to create, read, update, and
delete any resource), the app would also allow you to create, read, update or delete
Categories, Spaces, Things or Property values (MQTT).
Add a new Policy by clicking the + symbol as shown below and click
Save.
Figure 3.
The information of the new App access is displayed. You can't modify
these fields.
Client ID: Identification of this new app access.
Client Secret: Password for this particular app access. You can't modify
this field with your own data, but to create a new one, click
Reset Client Secret just at the right of this
field. Once clicked you will see that the field is filled automatically
and if you click on the eye icon in the field you will be able to see
the password. Also the password is displayed at the bottom center of the
screen in a notification box.
Save the Client ID and Client Secret in a secure location. You will need those
later in the process. You can use the Secrets Storage
function under Space Settings to store them.
