Create an OPC-UA Thing Schema
Example Schema
You need to define the Thing that is going to represent and store the data from selected nodes from the OPC-UA server.
The following is an example of a Thing schema that has two properties defined for
nodes present on the Milo demo server used in the discovery section:
"@type": [
"swx:opcua"
"actions": {
"readNodeValue": {
"input": {
"type": "string"
"title": "Read Node Value"
"events": {
"readNodeValue": {
"data": {
"type": "string"
"description": "",
"title": "Read Node Value Result"
"properties": {
"config": {
"properties": {
"auth": {
"type": "string"
"endpoint": {
"type": "string"
"intervalData": {
"type": "integer"
"mode": {
"type": "string"
"policy": {
"type": "string"
"type": "object"
"ns=2;s=Demo.Dynamic.Float": {
"@type": "float64",
"readOnly": true,
"title": "RandomFloat",
"type": "number"
"ns=2;s=Demo.Dynamic.Int32": {
"@type": "int32",
"readOnly": true,
"title": "RandomInt32",
"type": "integer"
"title": "OPC-UA Thing"
} Important parts of this schema are:
- The
@typeneeds to have an item with valueswx:opcua. Without it, the OPC-UA Device Driver will not process the schema. - The
configproperty (of type object) is used to set various OPC-UA configurations (see below). - The other two properties are configured to subscribe to specific nodes on the OPC-UA server.
- The
readNodeValueAction and Event can be used to manually retrieve a value from any OPC-UA node on the server.
OPC-UA Config Property
The config property is of the type object and can have various child
properties that are used for the OPC-UA configuration. The endpoint
is required.
The following property keys are allowed (see OPC-UA Driver):
- Basic
endpoint(required): this is the endpoint of the OPC-UA serverinterval(optional; default 30000): the subscription interval in milliseconds
- Advanced
mode(optional; defaultauto): the security mode to use, available optionsauto,None,Sign,SignAndEncryptpolicy(optional; defaultauto): the security policy to use, available optionsauto,None,Basic128Rsa15,Basic256,Basic256Sha256,Aes128_Sha256_RsaOaep,Aes256_Sha256_RsaPssautogencert(optional; defaulttrue): auto generate a self-signed cert if no certfile/keyfile are specifiedcertfile(optional): a public cert to use for communication with the endpointkeyfile(optional): the private key of the public certauth(optional; defaultAnonymous): the authentication method for the connection to the server. Available options includeAnonymous,Username, andCertificate"username(optional): needed when authentication method is set to Usernamepassword(optional): needed when authentication method is set to Username
