Telemetry Data
If only one property to report is specified then the telemetry will return just the value of that property. For example:
"data": {
"analog-input,0,present-value": "1197.831787"
"messageType": "propertyStatus",
"thingID": "01F6PEY4T318ZCQ6A0H638GWF6",
"timestamp": 1622451000004261
If multiple properties to report are specified then the telemetry will consist of an object with the properties as the keys and the return values as the object values. For example:
"data": {
"analog-input,0,present-value,units": {
"present-value": "1197.831787",
"units": "cubic-feet-per-minute"
