Generate BACnet Discovery Reports
Introduction
See the Reports section of the API documentation.
- bacnet-addresses
- bacnet-devices
The first type discovers address details and related info for the BACnet IP or MSTP (IP connected) physical devices on the network the Edge Cluster is on. The report can be fine-tuned by specifying certain input parameters.
The second type discovers data point instances and their parameters (values, properties, etc) related to BACnet device specified in the request body. The request body must match one obtained in stage (1). The report can be fine-tuned by specifying certain input parameters.
Discovery Type: bacnet-addresses
The following API request is used to request the "bacnet-addresses" report generation:
POST /reports/discovery/bacnet-addresses
with request body (fill in the correct values)
"bacnet-addresses": {
"input": {
"bacnet": {
"bacnet_discovery": {
"bacnet_mac_adress": "<hexidecial like 0A:26:00:4B:BA:C0",
"bacnet_destination_address": "<hexidecimal like 0A:26:00:4B:BA:C0",
"bacnet_destination_network": <>,
"bacnet_discovery_ID": <>,
"bacnet_maximum_ID": <>,
"bacnet_minimin_ID": <>,
"timestamp": <>
"bacnet_environment": {
"BACNET_IFACE": "eth0"
Here, the bacnet_discovery
object uses the same parameters as the
bacwi
utility. See the bacnet documentation for more information.
The bacnet_environment
object uses the same environment variables as
used by the bacnet-stack
, in particular interface (eth0
in
this example).
The bacnet-addresses
discovery request input can be simplified to
blank JSON object (i.e., {}). In this case bacnet will use device eth0
The whole request body can be as simple as this, using default parameters:
"input": {
The API response will include an href
parameter that can be used to
retrieve report details. It is structured as follows:
/reports/discovery/{discovery_type}/{report_id}
The report details returned include the status of the report.
Once the report has been completed details of the uploaded reports (by the BACnet driver to the core driver service) can be retrieved using the following API call:
GET /reports/discovery/{discovery_type}/{report_id}/uploads
The returned uploadId
values can be used to retrieve the reports by
GET /reports/discovery/{discovery_type}/{report_id}/uploads/{upload_id}
An example response (truncated) is as follows:
"devices": {
"999": {
"device-identifier": 999,
"ipaddress": "0A:26:00:E9:BA:C0",
"max-apdu-length-accepted": 1476,
"network-number": 0,
"saddress": "",
"segmentation-supported": false,
"updated": "1621927158",
"vendor-identifier": 36,
"vendor-name": "Tridium Inc."
"36000": {
"device-identifier": 36000,
"ipaddress": "0A:26:00:24:BA:C0",
"saddress": "",
"segmentation-supported": true,
"vendor-identifier": 556,
"vendor-name": "Obvius"
Discovery Type: Data Point Instances for Device
The following API request is used to request the bacnet-devices
report generation:
POST /reports/discovery/bacnet-devices
with request body (fill in the correct values, include an object for each device a report is needed for)
"bacnet-devices": {
"input": {
"devices": {
"999": {
< address section as returned by bacnet-addresses request >
"bacnet_requested_properties": {},
"timestamp": "%Z %F %T"
Here, the <address section>
for the requested device must be the
complete address as returned by the bacnet-addresses discovery report. Include all the
devices a discovery report is needed for.
The bacnet_requested_properties
input is blank in this example but
can contain properties requested for discovery for each data point type, as follows:
"device": [
"object-name",
"object-type",
"description",
"model-name",
"system-status",
"firmware-revision",
"application-software-version",
"vendor-name",
"object-identifier"
"analog-input": [
"units",
"present-value",
"object-name",
"object-type",
"description",
"COV-increment",
"object-identifier"
"analog-output": [
"units",
"present-value",
"object-name",
"object-type",
"description",
"COV-increment",
"object-identifier",
"priority-array",
"relinquish-default"
"analog-value": [
"units",
"object-name",
"object-type",
"description",
"COV-increment",
"object-identifier"
"binary-output": [
"present-value",
"object-name",
"object-type",
"description",
"priority-array",
"multi-state-output": [
"present-value",
"object-name",
"object-type",
"description",
"priority-array",
This allows fine-tuning properties requested for discovery.
, bacnet_requested_properties
and timestamp
input parameters can all be omitted, in which case default
values will be used (such as eth0
Using the bacnet-addresses
example response from the previous
section, a simple example for the bacnet_devices
discovery request for
device 999
only will look like the following. API endpoint:
with request body:
"bacnet-devices": {
"input": {
"devices": {
"999": {
"saddress": "",
values can be used to retrieve the reports bu
"999": {
"address": {
"saddress": "",
"application-software-version": "Tridium 3.8.38.9",
"description": "Local BACnet Device object",
"firmware-revision": "3.8.38.6",
"max-info-frames": "1",
"max-master": "127",
"model-name": "NiagaraAX Station",
"multiread": true,
"object-name": "CandiDemo_999",
"object-type": "device",
"objects": {
"999:0:0": {
"cov-increment": "1.000000",
"description": "Box Flow",
"object-identifier": "(analog-input, 0)",
"object-name": "VAV.BoxFlow",
"object-type": "analog-input",
"present-value": "1198.108887",
"rawtime_us": 1621928308682669,
"units": "cubic-feet-per-minute",
"updated": "1621928308"
"999:0:1": {
"description": "",
"object-identifier": "(analog-input, 1)",
"object-name": "Dummy Points.NumericInput",
"present-value": "0.000000",
"rawtime_us": 1621928308687010,
"units": "no-units",
