Create BACnet Thing Description
Introduction
See Things documentation on how to manage Things in Studio.
A Thing for this device driver uses a schema as described on this page.
Once it exists in Studio it can be synced to the Cluster (Asset) as shown on the Sync Things page.
The following is an example of a Thing description to be instantiated by the BACnet driver:
"@type": [
"BACnet",
"Meter",
"bacnet,777,AC:11:00:02:BA:C0,0,00,1476,eth0,true,260"
"id": "<leave blank when creating a thing>",
"title": "BACnetMeter",
"description": "My BACnet Meter",
"collection": "<set to the cloud collection to be used>",
"properties": {
"analog-input,7,present-value": {
"title": "inputType 0 inputIndex 7",
"description": "Return Temperature",
"type": "number",
"@type": "TemperatureProperty",
"unit": "Celsius",
"maximum": 200,
"readOnly": true
- the "bacnet,777,..." string in the "@type" array
- the "analog-input,7,present-value" property key
The first item is essential for the BACnet driver to recognise this Thing description as a BACnet device. Details on how to construct this string can be found in the next section.
The second item is essential for the BACnet driver to recognise the object it needs to manage. Details on how to construct property keys and the rest of the property object can be found in a subsequent section.
Construct the "bacnet,.." "@type"
The following element in the "@type"` array is required to specify bacnet device. It is comma-separated string of parameters.
It is entirely taken from bacnet address discovery report (also found in the bacnet
devices report as the "address" section). These also can be seen with
bacnet-stack bacwi
utility. Example below:
"777": {
"device-identifier": 777,
"ipaddress": "AC:11:00:02:BA:C0",
"max-apdu-length-accepted": 1476,
"network-number": 0,
"saddress": "",
"segmentation-supported": true,
"updated": "1587667968",
"vendor-identifier": 260
- keyword bacnet
- This is to indicate that device is bacnet device. Mandatory.
- device-identifier
- Bacnet device instance number (integer value). Mandatory. If no other parameters present driver uses "who is" broadcast call to discover the rest of the parameters, such as IP etc.
- Device IP
- Device IP and port in hex notation, such as AC:11:00:02:BA:C0 (ip 172.17.0.2) and port number (0xBAC0 == 47808). Optional.
- Network number
- Bacnet sub-network number. 0 in this example. Optional.
- Bacnet saddress
- 00 in this example. Optional.
- max-apdu-length-accepted
- In bytes. Optional.
- Interface
- Used by bacnet driver.
eth0
in this example, typical would beeth0
. Optional. - Segmentation supported
- True or false. Optional.
- Bacnet vendor ID
- Optional
In this particular example , the minimum requirement would be:
bacnet,777
In this case the driver will issue broadcast request "who is" and find the BACnet IP on its own.
If the BACnet IP is already known, it can be included as follows:
In this case the driver will use IP without issuing broadcast request to find it first. It means that bacnet device may not be on the local network at all.
Construct a Property
The data instances to report are specified as keys in "properties" section. Example below:
"analog-input,5,present-value": {
"description": "COV",
"type": "number",
"@type": "cov",
"maximum": 200,
"readOnly": true
The corresponding section of device discovery report is the following:
"objects": {
"777:0:5": {
"COV-increment": "1.000000",
"description": "ANALOG INPUT 5",
"object-identifier": "(analog-input, 0)",
"object-name": "ANALOG INPUT 5",
"object-type": "analog-input",
"present-value": "0.000000",
"rawtime_us": 1587669499279057,
"units": "percent",
"updated": "PDT 2020-04-23 12:18:19.279"
. Note that it uses textual names
for data types and properties, the same as in the discovery report. These are
defined in bacnet-stack library:- Data type
- Could be "analog-input", "analog-value", "binary-input" etc. Mandatory.
- Bacnet instance ID
- This is integer value taken from bacnet device discovery report. Mandatory.
- Property to report
- "Present-value" in this case. At least one property is mandatory.
- Second (third, etc) property to report. Optional. For instance string could look like "analog-input,5,present-value,units"
