Thing Description OTAA Device
Example Thing Description
See Things documentation on how to manage Things in Altair IoT Studio.
A Thing for this device driver uses a schema as described on this page.
Once it exists in Studio it can be synced to the Cluster (Asset) as shown on the Sync Things page.
  "@type": [
    "swx:lorawan,devEUI=,deviceProfileID="
  "id": "<leave blank when creating a thing>",
  "title": "LoRaWAN Test Device",
  "properties": {
    "myReadProperty": {
      "title": "My Read Property",
      "type": "number",
      "readOnly": true
    "myWriteProperty": {
      "title": "My Write Property",
      "type": "number",
      "@type": [
          "swx:lorawan,f_port=1"
      "readOnly": false
    "enabled": {
      "title": "Enabled",
      "type": "boolean",
      "readOnly": false
  "actions": {
    "getActivation": {
      "title": "Get activation",
      "description": "Get activation details for device"
    "getDeviceKeys": {
      "title": "Get device keys",
      "description": "Get device keys for OTAA device"
    "setDeviceKeys": {
      "title": "Set device keys",
      "description": "Set device keys for OTAA device",
      "input": {
        "type": "object",
        "properties": {
          "nwk_key": {
            "type": "string"
    "deleteDeviceKeys": {
      "title": "Delete device keys",
      "description": "Delete device keys for OTAA device"
    "listDeviceQueueItems": {
      "title": "List deviceQueue items",
      "description": "List deviceQueue items",
      "input": {
        "type": "object",
        "properties": {
          "countOnly": {
            "type": "boolean"
    "flushDeviceQueue": {
      "title": "Flush deviceQueue",
      "description": "Flush deviceQueue"
    "enqueue": {
      "title": "Add item to deviceQueue",
      "description": "Add item to deviceQueue",
      "input": {
        "type": "object",
        "properties": {
          "f_port": {
            "type": "integer"
          "data": {
            "type": "string"
          "object": {
            "type": "string"
          "is_pending": {
            "type": "boolean"
          "is_encrypted": {
            "type": "boolean"
          "expires_at": {
            "type": "string"
  "events": {
    "getActivation": {
      "title": "getActivation request is done",
      "description": "response of getActivation request",
      "data": {
        "type": "object"
    "getDeviceKeys": {
      "title": "getDeviceKeys request is done",
      "description": "response of getDeviceKeys request",
      "data": {
        "type": "object"
    "setDeviceKeys": {
      "title": "setDeviceKeys request is done",
      "description": "response of setDeviceKeys request",
      "data": {
        "type": "object"
      "title": "listDeviceQueueItems request is done",
      "description": "response of listDeviceQueueItems request",
      "data": {
        "type": "object"
    "enqueue": {
      "title": "enqueue request is done",
      "description": "response of enqueue request",
      "data": {
        "type": "object"
      The device profile has the flag to mark it as an OTAA device.
Configuration Using the "@type"
"@type" is used to set two required configuration parameters: devEUIdeviceProfileID
The devEUI is a 64-bit globally-unique Extended Unique Identifier (EUI-64)
        assigned by the manufacturer, or the owner, of the end-device. It should be set in the
        "@type" of the Thing.
The deviceProfileID is the unique identifier for the device profile
        specific for this device (class). Device profiles can be managed through the API. See the
        appropriate help page.
There is an optional applicationID parameter. If omitted it will use the
        default generated application (highly recommended). However, applications can be managed
        through the device driver API and the Thing description can be set to use a specific
        application.
Configuration Using Thing Properties
@type, the
        configuration can be set using properties on the thing
        schema."properties": { "config": { "properties": { "devEUI": { "title": "Device EUI", "type": "string" }, "deviceProfileID": { "title": "Device Profile ID", "type": "string" } }, "title": "LoRa Configuration", "type": "object" }, "enabled": { "title": "Enabled", "type": "boolean" }, "skipFrameCountCheck": { "title": "Skip Frame Counter Validation", "type": "boolean" },
devEUI and deviceProfileID are part of the
          config property (object).swx:lorawan as the @typeAvailable Actions
An OTAA device needs to have an AppKey set in both the LoRa Server Stack and the device to allow automatic join and activation.
- setDeviceKeys
 - The network key (or application key) (nwk_key) is a 128 bits AES-128 key and needs to be set both at the application server and the end device. The key can be auto-generated by the LoRaWAN device driver by sending in the "generate" (string) value.
 - getDeviceKeys
 - This retrieves the device keys.
 - deleteDeviceKeys
 - This will delete the device keys and, therefor, de-activate the device.
 - getActivation
 - The activation details can be retrieved using the
getActivationAction. - enqueue
 - Messages to be sent to the end-device can be added to the queue by running this Action.
 - listDeviceQueueItems
 - This will list all outstanding, queued items.
 - flushDeviceQueue
 - This will flush (delete) all outstanding, queued items.
Writeable Property
LoRaWAN does not have the notion of writing/setting a property (or running an Action, for that matter); it is only possible to enqueue a message that then need to be processed by the device.
There is already a (generic) Action on the Thing description to enqueue a message. Apart
        from the message body itself (either as binary data (i.e., base64 encoded), or as a JSON
        object (only if the device profile has a codec set)) this requires an fPort
        to be specified.
The device driver has "setProperty" functionality using the "enqueue" mechanism. Since this
        needs an fPort, it is possible to specify the fPort in the
          "@type" of the property itself. If not set, a default value of 1 is used.
        It is up to the end device to use (validate/verify) the fPort value.
Example of property definition:
"thermostat": { "title": "Thermostat", "type": "number", "@type": [ "swx:lorawan,f_port=1" ], "readOnly": false },
