Thing Description ABP Device
Example Thing Description
See Things documentation on how to manage Things in Altair IoT Studio.
A Thing for this device driver uses a schema as described on this page.
Once it exists in Studio it can be synced to the cluster (asset) as shown on the Sync Things page.
"@type": [
"swx:lorawan,devEUI=,deviceProfileID="
"id": "",
"title": "LoRaWAN Test Device",
"properties": {
"myReadProperty": {
"title": "My Read Property",
"type": "number",
"readOnly": true
"myWriteProperty": {
"title": "My Write Property",
"type": "number",
"@type": [
"swx:lorawan,f_port=1"
"readOnly": false
"enabled": {
"title": "Enabled",
"type": "boolean",
"readOnly": false
"actions": {
"getActivation": {
"title": "Get activation",
"description": "Get activation details for device"
"activate": {
"title": "Activate",
"description": "Activate ABP device",
"input": {
"type": "object",
"properties": {
"dev_addr": {
"type": "string"
"app_s_key": {
"type": "string"
"nwk_s_key": {
"type": "string"
"deactivate": {
"title": "Deactivate",
"description": "Deactivate ABP device"
"listDeviceQueueItems": {
"title": "List deviceQueue items",
"description": "List deviceQueue items",
"input": {
"type": "object",
"properties": {
"countOnly": {
"type": "boolean"
"flushDeviceQueue": {
"title": "Flush deviceQueue",
"description": "Flush deviceQueue"
"enqueue": {
"title": "Add item to deviceQueue",
"description": "Add item to deviceQueue",
"input": {
"type": "object",
"properties": {
"f_port": {
"type": "integer"
"data": {
"type": "string"
"object": {
"type": "string"
"is_pending": {
"type": "boolean"
"is_encrypted": {
"type": "boolean"
"expires_at": {
"type": "string"
"events": {
"getActivation": {
"title": "getActivation request is done",
"description": "response of getActivation request",
"data": {
"type": "object"
"activate": {
"title": "activate request is done",
"description": "response of activate request",
"data": {
"type": "object"
"title": "listDeviceQueueItems request is done",
"description": "response of listDeviceQueueItems request",
"data": {
"type": "object"
"enqueue": {
"title": "enqueue request is done",
"description": "response of enqueue request",
"data": {
"type": "object"
The device profile has the flag to mark it as an ABP device.
Configuration Using the "@type"
"@type" is used to set two required configuration parameters:devEUIdeviceProfileID
The devEUI is a 64-bit globally-unique Extended Unique Identifier (EUI-64)
assigned by the manufacturer, or the owner, of the end-device. It should be set in the
"@type" of the Thing.
The deviceProfileID is the unique identifier for the device profile
specific for this device (class). Device profiles can be managed through the API. See the
appropriate help page.
There is an optional applicationID parameter. If omitted it will use the
default generated application (highly recommended). However, applications can be managed
through the device driver API and the Thing description can be set to use a specific
application.
Configuration Using Thing Properties
@type, the
configuration can be set using properties on the thing
schema."properties": { "config": { "properties": { "devEUI": { "title": "Device EUI", "type": "string" }, "deviceProfileID": { "title": "Device Profile ID", "type": "string" } }, "title": "LoRa Configuration", "type": "object" }, "enabled": { "title": "Enabled", "type": "boolean" }, "skipFrameCountCheck": { "title": "Skip Frame Counter Validation", "type": "boolean" },
devEUI and deviceProfileID are part of the
config property (object).swx:lorawan as the @type.Available Actions
- activate
- An ABP device needs to have
DevAddr,AppSKeyandNwkSKeyset in both the LoRa Server Stack and the device to allow join and activation. TheDevAddr,AppSKeyandNwkSKeycan be set (create or update) using theactivateAction. - deactivate
- The
deactivateAction will deactivate the device. - getActivation
- The activation details can be retrieved using the
getActivationAction. - enqueue
- Messages to be sent to the end-device can be added to the queue by running this action.
- listDeviceQueueItems
- This will list all outstanding, queued items.
- flushDeviceQueue
- This will flush (delete) all outstanding, queued items.
Writeable Property
LoRaWAN does not have the notion of writing/setting a property (or running an action, for that matter); it is only possible to enqueue a message that then need to be processed by the device.
There is already a (generic) action on the Thing description to enqueue a message. Apart
from the message body itself (either as binary data (i.e., base64 encoded), or as a JSON
object (only if the device profile has a codec set)) this requires an fPort
to be specified.
The device driver has "setProperty" functionality using the "enqueue"
mechanism. Since this needs an fPort, it is possible to specify the
fPort in the "@type" of the property itself. If not set,
a default value of 1 is used. It is up to the end device to use (validate/verify) the
fPort value.
Example of property definition:
"thermostat": { "title": "Thermostat", "type": "number", "@type": [ "swx:lorawan,f_port=1" ], "readOnly": false },
