LoRa Gateway Installation
The LoRa Gateway can be deployed by adding the "App - ECP LoRa Gateway" to your Space from the Marketplace.
Supported Hardware
- RAK2246
 - RAK2247 (SPI and USB)
 - RAK2287
 - RAK5146
 - RAK7243
Variables (Override Parameters)
The following are required to run with the correct version of the packet
                    forwarder:
            - MODEL (RAK2246, RAK2247, RAK2287, RAK5146, RAK7243)
 - TYPE (SPI, USB, I2C, UART)
 - REGION (see below)
 - RESET_PIN (optional, default 17)
 - GATEWAY_ID (see below)
Note: The server address and ports are automatically set when used with the LoRa Server
                Stack.
        Region
- AS_915_921
 - AS_915_928
 - AS_917_920
 - AS_920_923 (alternative: AS923)
 - AU_915_928 (alternative: AU915)
 - CN_470_510 (alternative: CN470)
 - EU_433 (alternative: EU433)
 - EU_863_870 (alternative: EU868)
 - IN_865_867 (alternative: IN865)
 - KR_920_923 (alternative: KR920)
 - RU_864_870 (alternative: RU864)
 - US_902_928 (alternative: US915)
Gateway ID
Some hardware will have a pre-defined gateway ID. If so, it needs to be set in the appropriate override parameter.
If not, then the LoRaWAN Driver can auto-generate one (see the LoRaWAN Driver page) and that value would need to be retrieved using the API and filled in here. In that case the LoRaWAN Driver should be installed before the LoRa Gateway is installed.
Alternatively, a user can define a Gateway ID and fill in for both the LoRa Gateway
                and the LoRaWAN Driver.
        Note: if the Gateway ID for the LoRaWAN
                    Driver is set to the value "generate" then the LoRa Gateway configuration for
                    the Gateway ID can be set to the value "driver" and it will automatically pick
                    up the auto-generated ID.
Note: if the LoRaWAN
                    Driver is uninstalled and then re-installed, using the "generate" Gateway ID
                    configuration, then the LoRa Gateway will have to be restarted
