Fleet Assets in AnythingDB
AnythingDB provides the backbone for EdgeOps. Each Asset in EdgeOps Fleet Management is represented in AnythingDB automatically, so you can interact with it.
In AnythingDB, for every Asset you provision, you will find a corresponding Thing in the Cluster category. Using actions and events, you can interact with your Edge device from this section. Check Asset Thing Details in AnythingDBfor more information.
