Fleet Management
Fleet Management enables you to create, monitor, and interact with all the Assets in your ecosystem. This gives you a high level view of what you have deployed and where. The Fleet Management section is divided into the following sections:
  • Asset Management: enables you to add new Assets to your Space for both installation on bare metal or by deploying a pre-installed OS
  • Installer Images: allows you to create an installable image for an Asset that can be downloaded and flashed to an USB drive using balenaEtcher
  • Edge Provisioning: allows for the automatic installation of a Distributions (a predefined set of Edge Applications) on any new Asset of a Fleet when it first connects to the IoT Studio Platform
  • Asset Configurations: enables you to configure Edge Assets based on their MAC address(es)
Also in This Section
