LoRaWAN Stack
Installation
The LoRaWAN Stack can be deployed by adding the "App - ECP LoRaWAN Stack" to your Space from the Marketplace.
This will deploy (Chirpstack components):
  • gateway bridge
  • combined network/application/join server
And the dependencies:
  • postgresql
  • redis
  • mosquitto
The stack is initialized so that all the pieces can talk to each other. The gateway bridge itself is available on port 1700 (UDP) of the ecp-lorawan-stack-gateway-bridge service (internal to the cluster) and can be exposed as a node port if necessary (for use with external LoRa gateways).
The network band defaults to "EU868" and can be set using the "Network Enabled Region" override parameter in the deployment (see Add an Edge App to Your Space).
Note that you might want to consult the LoRaWAN Regional Parameters specification for valid values that apply to your region. See: https://www.lora-alliance.org/lorawan-for-developers.
The options available in the deployment configuration are based on the Chirpstack region configurations where the deciding factor is the enabled uplink channels section.
Valid values, to use as value for the "Network Enabled Region" override parameter, are:
  • as923
  • as923_2
  • as923_3
  • as923_4
  • au915_0 (enabled_uplink_channels = [0, 1, 2, 3, 4, 5, 6, 7, 64])
  • au915_1 (enabled_uplink_channels = [8, 9, 10, 11, 12, 13, 14, 15, 65])
  • au915_2 (enabled_uplink_channels = [16, 17, 18, 19, 20, 21, 22, 23, 66])
  • au915_3 (enabled_uplink_channels = [24, 25, 26, 27, 28, 29, 30, 31, 67])
  • au915_4(enabled_uplink_channels = [32, 33, 34, 35, 36, 37, 38, 39, 68])
  • au915_5 (enabled_uplink_channels = [40, 41, 42, 43, 44, 45, 46, 47, 69])
  • au915_6 (enabled_uplink_channels = [48, 49, 50, 51, 52, 53, 54, 55, 70])
  • au915_7 (enabled_uplink_channels = [56, 57, 58, 59, 60, 61, 62, 63, 71])
  • cn470_0 (enabled_uplink_channels = [0, 1, 2, 3, 4, 5, 6, 7])
  • cn470_1 (enabled_uplink_channels = [8, 9, 10, 11, 12, 13, 14, 15])
  • cn470_2 (enabled_uplink_channels = [16, 17, 18, 19, 20, 21, 22, 23])
  • cn470_3 (enabled_uplink_channels = [24, 25, 26, 27, 28, 29, 30, 31])
  • cn470_4 (enabled_uplink_channels = [32, 33, 34, 35, 36, 37, 38, 39])
  • cn470_5 (enabled_uplink_channels = [40, 41, 42, 43, 44, 45, 46, 47])
  • cn470_6 (enabled_uplink_channels = [48, 49, 50, 51, 52, 53, 54, 55])
  • cn470_7 (enabled_uplink_channels = [56, 57, 58, 59, 60, 61, 62, 63])
  • cn470_8 (enabled_uplink_channels = [64, 65, 66, 67, 68, 69, 70, 71])
  • cn470_9 (enabled_uplink_channels = [72, 73, 74, 75, 76, 77, 78, 79])
  • cn470_10 (enabled_uplink_channels = [80, 81, 82, 83, 84, 85, 86, 87])
  • cn470_11 (enabled_uplink_channels = [88, 89, 90, 91, 92, 93, 94, 95])
  • cn779
  • eu433
  • eu868
  • in865
  • ism2400
  • kr920
  • ru864
  • us915_0 (enabled_uplink_channels = [0, 1, 2, 3, 4, 5, 6, 7, 64])
  • us915_1 (enabled_uplink_channels = [8, 9, 10, 11, 12, 13, 14, 15, 65])
  • us915_2 (enabled_uplink_channels = [16, 17, 18, 19, 20, 21, 22, 23, 66])
  • us915_3 (enabled_uplink_channels = [24, 25, 26, 27, 28, 29, 30, 31, 67])
  • us915_4 (enabled_uplink_channels = [32, 33, 34, 35, 36, 37, 38, 39, 68])
  • us915_5 (enabled_uplink_channels = [40, 41, 42, 43, 44, 45, 46, 47, 69])
  • us915_6 (enabled_uplink_channels = [48, 49, 50, 51, 52, 53, 54, 55, 70])
  • us915_7 (enabled_uplink_channels = [56, 57, 58, 59, 60, 61, 62, 63, 71])
Links
Chirpstack
