MQTT Subscribe Workflow
                To handle the communication from IoT Studio to Embed, from the
                        Blocks/ Extensions/ IoT menu, add an MQTT Subscribe
                    block and configure it with the information related to the EdgeDevice Thing
                    create in IoT Studio.
                Enter the required parameters as explained below (optional are the same as in
                    the previous section for the publishing workflow):
- Host Name: Specifies the MQTT broker address. For IoT Studio, use mqtt.swx.altairone.com.
 - Topic: Specifies the MQTT topic on which the
                            message is to be published. It should look like
spaces/{space}/things/{thingId}/properties/Temperature - Username and Password: MQTT credentials of your Thing. They are needed to allow to send the data to your Thing. Information about how to get them can be found Manage Security
 - Keep Alive: Make sure it is set to 0.
 - From the Blocks/ Extensions/ IoT menu, add a JSON Get Value block. This block reads the JSON-formatted string and outputs the value of the specified key. Link the MQTT Subscribe block as the JSON input of the Get Value block.
 - From the Blocks / Signal Producer menu add a const block and enter "Temperature". Link this as the input key value of the JSON Get Value block.
 - From the Blocks / Signal Consumer menu, add a display block and link it as the output of the JSON Get Value block.
                When Go is selected, the Embed diagram begins executing
                    sending data to IoT Studio every 0.5 seconds. A video of the two applications
                    communicating is presented below:
Detailed information about the Embed blocks can be found below.
