From the Blocks / Signal Producer menu, choose the
following inputs:
A pulseTrain and configure it with a Time Between Pulses of 0.5
seconds
A const and enter "Temperature". The double quotes surrounding
Temperature indicate a string value
A sinusoid and set it to a frequency of .159 Hz
From the Blocks/ Extensions/ IoT menu, add a JSON Create String block and link the three blocks
created before to it.
From the Blocks / Signal Consumer menu, add a display
block and link it as the output of the JSON Create String block.
Select Go.
The JSON string appears as follows:Figure 2. The output string will be sent to IoT Studio via MQTT.
From the Blocks/ Extensions/ IoT menu, add an MQTT
Publish block and configure it with the information related to the EdgeDevice
Thing created in IoT Studio. The required parameters are explained below:
Host Name: Specifies the MQTT broker address. For
IoT Studio, use mqtt.swx.altairone.com.
Topic: Specifies the MQTT topic on which the
message is to be published. It should look like
spaces/{space}/things/{thingId}/properties
Username and Password: MQTT credentials of your
Thing. They are needed to allow to send the data to your Thing.
Information about how to get them can be found in Manage Security.
Default settings are used for the remaining parameters:
QoS: Specifies the quality of service to the
server. Your choices are:
0: Sends the message once with no guarantee of delivery. The
server does not acknowledge delivery.
1: Guarantees message delivery, but it could send duplicates.
The server acknowledges delivery.
2: Guarantees message delivery without duplicates. The server
acknowledges delivery, then both the server and publisher
discard the stored messages.
Port: Indicates the port that the broker is
using. The default unencrypted port is 1883; the default encrypted port
is 883.
Keep Alive: Specifies the maximum time interval
between when the client finishes sending a PING message to the broker
and starts to send the next PING message. The maximum time interval is
18 hours, 12 minutes, and 15 seconds. If it is set to 0, the keep alive
mechanism is de-activated and Last Will and Testament is ignored. The
default time interval is 60 sec.
Retain last message on server: Retains the last
message if the publisher unexpectedly disconnects.
Click GO to start sending the data to IoT Studio every
0.5 seconds.
Open the EdgeDevice Thing Details panel. Open the properties-history and check
how the data is being stored on the database in real time. If you open the MQTT
Inspector under the Utility Belt, you can also check the incoming
messages.
