JSON Get Value Block
The JSON Get Value block reads the JSON-formatted string and outputs the value of the specified key. In its default form, this block has two input pins (json str and key) and one output pin (value str).
- json str
 - JSON input string
 - key str
 - Input string key
 - value str
 - Value extracted from the corresponding key string
