Configure the ECP App
Once the Access app is created, you can configure the Edge Compute Platform app.
                Click  and click App - Edge Compute Platform.
                A new section is displayed on the right.
 - Select the version to use, or use the latest that is recommended by clicking on the drop down box next to the Delete button.
                To configure it, click Configuration.
The following tab opens:Figure 3.
 - Enter the name and description of the new configuration.
                Under the App - ECP Support IoT Studio section, enter
                    the following information:
Option Description Access Control App Client ID The client ID of the access app you created in the previous step. Access Control App Client Secret The client secret of the access app you created in the previous step.  - Click Save.
