Deploy the Code at the Edge to Emulate Data Streaming
                Repeat Steps 1-5 in Configure the ECP App to deploy the
                    Virtual Meter Edge Application.
- Add the App from the Marketplace.
 - Navigate to the Edge Applications section, choose the App - ECP Virtual Meter and create a deployment.
 - Choose your Raspberry Pi 4 device from the section and add the new Edge Application from the Applications tab.
Once the Virtual Meter Edge Application is deployed to your device, you
                need to define the Thing that is going to represent and store the data from this
                virtual meter.
                Create a new Category in the AnythingDB section named
                        Meters. Select to add a new Thing to this category,
                    and choose to skip to schema. Add the following
                    schema:
{ "@type": [ "swx:Meter", "swx:Virtual" ], "id": "<leave blank when creating a thing>", "title": "Meter", "description": "Virtual Meter", "category": "Meters", "properties": { "UD_DTYPE_KWH_ODM": { "title": "kWh ODM", "type": "number", "readOnly": true }, "UD_DTYPE_KW_AVG": { "title": "kW", "type": "number", "readOnly": true, "minimum": -5, "maximum": 25 }, "dataUsagePollSecs": { "title": "Data Usage Poll Secs", "type": "integer", "readOnly": false } }, "actions": { "correctKwhOdm": { "input": { "title": "Correct the kWh ODM value", "type": "object", "properties": { "newValue": { "title": "The new value", "type": "number" } } } } }, "events": { "negativeKw": { "title": "Negative kW", "description": "kW Usage is Negative", "data": { "type": "number" } } } } -
                Sync this Thing to the Virtual Meter application.
