Scoring Agent
Multiple copies of the Marketplace application for the RapidMiner Scoring Agent can be added to your Space. This way, you can run different scoring agents with different libraries.
Each instance has a unique identifier which needs to be used as the "scoring agent ID" for the Support RapidMiner application. The configuration options for deploying an instance are described below.
