Deploy a Function to the Edge
Management of functions at the edge is done via API requests. See “OpenAPI > ECP > Support Services > Functions” for more information.
To deploy a function to the edge, a POST request needs to be made as follows:
POST /support/faas/functions
With a minimum request body:
 “name”: “<edge-function-name-as-built-on-the-cloud>”
This will deploy the function that was built on the cloud side.
Optionally, environment values can be set and topics for the telemetry triggers (see section “Invoke a Function > On a Telemetry Trigger”):
  “name”: “<edge-function-name-as-built-on-the-cloud>”,
  “env_vars”: {
  “var_1”: “value_1”
  “topics”: [
  “things/<thing-uid>/properties”
