Fleet Management in SmartWorks IoT is where you can see, monitor, and interact with
all the
Clusters in your ecosystem. This gives you a high
level view of what you have deployed and where.
Note: The term "Cluster" is used in the same way that Kubernetes does - a
collection of independently running services which together form a cohesive set
of instructions. This does not imply there are multiple parrallel computers. In
fact, often a "Cluster" may be comprised of a single
gateway.
