Resource Catalog
The Resource Catalog holds YAML files which reference your code as well as ours. We have specified manage Resource Manifests in the Edge Compute Platform section which you can use to create the ECP. Simply create Resources for the manifests you wish to use, and copy/paste the YAML we have specified into the template. These can then be grouped together in Edge Applications later.
Create a New Resource
From the Resource Catalog menu, click + New Resource .
- Name the resource and enter its description.
- Select the type from the Type drop-down menu, and select whether the resource is public or private.
Write the resource in YAML format.
Click Save.
A message is displayed, the resource appears on the left panel in the Resource Templates list, and icons to edit the resource become available.
- Click the Edit icon.
- Click Add Parameter.
Enter the Name, Description and the Key of the parameter and click
Save.
The Name is used for display in the Deployment section of the Edge Application, the Description is used for the help text and the Key is a dot-separated representation of the yaml element the user is allowed to override.
Parameters successfully set message appears.
