Exchange ase.exchange.api
Setup
User: api-user
Permissions: the API user can only publish to the ase.exchange.api exchange and create callback queues that need to start with ase.callback.api. (with a unique suffix). This way the user is limited to using the API only. (Use correlationId and callback queue.)
Outgoing Messages
The message format and headers to be published to this exchange are described in the API section. An example is as follows:
Exchange Headers Body
ase.exchange.api
requestMethod=PUT
href=/things/itMmuV7uNt3onfDldnoR/properties/temperature
{"temperature":34}
