Altair IoT Studio provides a tool, the API Inspector, to get familiar with
and interact with the API structure. Requests can be made through the API Inspector
without having to worry about authentication details, as this information is
automatically populated.
The API Inspector can be found under Utility Belt in the left
side menu:Figure 1.
To check the Property's history, click next to the
Properties section.
To check the history of a specific Property, click next to the
Property. Note that a time range can be selected to filter the Property's
history.
Figure 4.
Send Data through MQTT or HTTP
You can establish bidirectional communication with your asset using MQTT or HTTP and
seamlessly integrate it into your application. Depending on your needs, you can
choose the appropriate protocol and configure it accordingly. The Thing's
Credentials can be found on the Interfaces tab. If your Thing does not yet have
Credentials, click Create Credentials.
Note: HTTP follows OAuth protocol. Once the credentials
have been created, the Client ID will always remain the same. The Client Secret
can be reset by clicking the Reset Client Secret
button.
Note: If you use MQTT, note that the
username and the password can be changed at any time. Choose to autogenerate the
Credentials or enter your own values. For this second option, don't forget to
click Save using the top right button.
