Create a Category and Thing
AnythingDB is a specialized, flexible, secure database to help you create a Model of the world and then display it in your application. In-depth information on AnythingDB can be found in AnythingDB topic.
The Categories menu is displayed by default. If you have
not created a Category yet, it will be labelled "– No
Categories –"
Figure 1. Category creation tab
Click New Category.
- Name the Category Sensors and click Create.
Things represent the entities in your world, for example your Sensors module. You can create a Thing using diverse methods. You can get more information in AnythingDB. For this training we will create a Thing from scratch.
To add a Thing, in the top right corner of the web editor, click +
New Thing .
A new window opens, labeled New Thing.Figure 2.
- In the dialog, enter the Thing name as detection and add a description.
Click Create.
The detection Thing will be added in the Things tab of AnythingDB.
