Before you can start building your IoT ecosystem, you must define a Space for your project to live in.
Note: Name your Space carefully, it is not editable and is used in
URL references later. Space names must be unique, even among
other users. If a Space name has already been used, the
following message will appear:Figure 1.
To create a new Space, click the tile to create a new
Space to build your IoT project.
Enter your Space name and click
Create.
The Space is saved, and the Altair IoT Studio "Let's start building!" screen appears.
Click Let's start building!
The home screen appears, with the Welcome to Altair IoT Studio! banner displayed.
You can create multiple Spaces, and toggle between them as
necessary. To create more Spaces or access previously
created Spaces, click Switch Space in the header of the page.
Manage Invitations
If you are invited to another Space, an invitation will appear.
Figure 3.
Select whether to accept or reject the invitation.
Tip: To leave a Space you
have been invited to, switch to the Space to leave,
click Space Settings > General, and click Leave Space in the upper right hand corner.
