Add a Cron Expression
Enter a Cron Expression if you want to schedule the Function's invocation. If
it is the first time you are creating one, click + Add cron
trigger to automatically create one and enable the input field.
Check here for Cron expressions
requirements.
Note that accessing the Triggers section will show you this new Cron trigger
created.
