Invoke the Function
Once the Function is running, it's ready to be invoked.
To invoke a Function, create a Trigger by clicking .
Note: A Trigger is a component that is capable of invoking serverless Functions from an event source. A Trigger works as a listener to a particular endpoint.
- Click Add.
- In the New Event Trigger panel, enter the Trigger description and Type.
- Under Config, enter the host as mqtt.swx.altairone.com.
- Enter your MQTT username and password same as in Interface tab inside the Thing in AnythingDB or Autogenerate it.
Add Topic as follows:
spaces/Your space name/things/Your thing ID/properties/humidity - Click Create Trigger.
To test the Trigger, update the humidity property to 30.
It will update the humidity_status property. Also, the Invocation count will change to 1.This Trigger points to the property humidity, of the thing “Your Thing ID” inside the space “Your space name”.
