Create a Thing in AnythingDB
AnythingDB is a specialized, flexible, secure database to help you create a Model of the world and then display it in your application.
Things represent the entities in your world, for example, your Arduino Board and sensors. You can create a Thing using diverse methods.
In-depth information on AnythingDB can be found in the Online Help.
  1. From the left hand menu, click AnythingDB > Things.
  2. To add a Thing, in the top right corner of the web editor, click + New Thing .
    A new window opens, labeled New Thing.
  3. In the dialog, enter the Thing name as Arduino and add a description. Select the Category Arduinos from the Categories drop down menu.
  4. Click Create.
    The Arduino Thing will be added in the Things tab of AnythingDB.
