Stream Processing is a method of tracking and analyzing streams of information of an event, and eventually obtaining useful structured
conclusions out of that raw information.
SmartWorks IoTEdgeOps is a set of tools for building, maintaining and continuously improving code in resource constrained devices at the
edge of smart product ecosystems.
After clicking on a Function, a menu as shown below is displayed. Figure 1.
In the General tab, edit the function:
Option
Status
Indicates if the function is deployed or not.
Endpoint
Enable/disable the endpoint.
Note: You can delete a function without
disabling it first.
Function description.
Invocations
Indicates the number of times the Function has been called.
Click on the Code tab to edit the code associated with the
Function. All changes related to code (change of template and the code itself)
can be edited from here.
Click on the Test button. This opens the API inspector
to test the invocation of your Function. It allows you to "send" the inputs
parameters to the Function and receive the solution in the test response
section.
You can also try the following endpoints to retrieve the inputs and the
outputs of your function:
