Actions
Actions are an interface for operating the entity according to what the entity is supposed to do.
Actions handle the communication with the device to manipulate properties, mandate changes in the state of the device, set timings for those states and trigger different activities on the device.
Actions follow a very similar format to Properties (and indeed, to Events). AnythingDB provides a schema for defining Actions, and metadata keys for describing them in detail.
Metadata Definition | Description | Required? | Type |
title |
Title of the action displayed in the UI | No | string |
description |
Additional content to tell the user what the action is for. | No | string |
input |
Defines the expected format of the action body. | No | object |
Many Actions are a simple command like "turn on" or "turn off". However, other times, Actions require parameters in the command like "Change Volume", where the Action command needs to specify not just that the volume should change but what it should change to.
These Action command parameters are defined in the input
metadata
key, in the Action description. This input
key follows the same
rules as a property - it can be defined by a primitive type
and
then, based on the type
, further defined by other metadata
keys.
array
- Expects a list of results
boolean
- Expects a true/false
number
- Expects any real number
integer
- Expects any whole number
object
- Expects a JSON object with additional properties defined.Note: Using Object type properties, you can nest properties within properties to create rich structures.
string
- Expects a series of letters and/or numbers
null
- Expects no value
title |
Title of the action input | No | string |
description |
Additional content to tell the user what the action input is for. | No | string |
unit |
Provides a reference unit, especially for numbers and integers. | No | string |
readOnly |
Validates that a value should not be written to. | Yes (default is false ) |
boolean |
minimum |
Minimum value. Used for validation. | No | number |
maximum |
Maximum value. Used for validation. | No | number |
minimum |
Minimum value. Used for validation. | No | integer |
maximum |
Maximum value. Used for validation. | No | integer |
"actions": {
"toggleOn": {
"title": "Turn On/Off",
"description": "This action turns the stereo on or off, depending on the stereos current state."
"volumeChange": {
"title": "Change the volume",
"description": "Change the volume of the Sound Stereo System over a set interval",
"input": {
"type": "object",
"properties": {
"level": {
"type": "integer",
"minimum": 0,
"maximum": 100
"volumeLevelDuration": {
"type": "integer",
"minimum": 0,
"unit": "seconds"
