Create a Blank Thing
To add a Thing, in the top right corner of the web editor, click +
New Thing .
A new window opens, labeled New Thing. - To create a new Thing, select one of the following alternatives:
Method: Start from scratch
Enter the information in the fields shown and click
Create. Title is required and description is
optional.
The Thing is created. To add or edit more information about the Thing, click the Thing in the list and enter the information on the Overview panel.
Method: Add the Thing to a Category previously defined.
Title is required; a description is optional. From the dropdown, choose the
Category or Categories you want to assign this Thing to and click
Create.
Method: Apply a Model previously defined to a new Thing
Click Apply model and select a Model from the drop down
menu. By default the latest Version of the Model will be assigned.
If the Model already has a Title it automatically displays in the Title field. If not, you need to add it.
- Click Create.
