Set Up the ESP32 and Arduino IDE
- Check the documentation available here to get Started with Arduino.
                Check the documentation available here to install the Smart Home Kit.
                These are the items available in the smart home:Sensors
Gas Sensor Detects gas leaks or the presence of gases. Humidity and Temperature Sensor Monitors the moisture and temperature levels in the environment. PIR Sensor Detects motion, typically used for security purposes. Raindrop Sensor Detects rain, which is used to automate responses like closing windows. RFID Sensor Used for access control or identification, typically for secure entry or item tracking. Controlled ItemsFan This can be turned on or off based on the temperature or other triggers. LED Simple lighting control. RGB LED Multicolor LED that can be controlled for different lighting effects. Door Automated opening and closing, controlled by sensors or remote commands. Window Automated opening and closing, can be controlled in response to weather conditions like rain. User ControlsControl Buttons Allow manual toggling of devices like the fan, lights, or door. LCD Display Panel Shows real-time data such as current temperature, humidity, gas levels, or system messages.
