Create a Thing to Define Your Device
AnythingDB is a specialized, flexible, secure database to help you create a Model of the world and then display it in your application. In-depth information on AnythingDB can be found in AnythingDB topic.
Things represent the entities in your world, for example your ESP8266 module. You can create a Thing using diverse methods, as highlighted in the image below. You can get more information in the AnythingDB topic. For this training we will create a Thing from scratch.
To add a Thing, click and click + New Thing .
A new window opens, labeled New Thing.Figure 1.
- In the dialog, enter the Thing name as NodeMCU and add a description.
Click Create.
The NodeMCU Thing will be added in the Things tab of AnythingDB.
