Create a Thing in AnythingDB
AnythingDB is a specialized, flexible, secure database to help you create a Model of the world and then display it in your application.
Things represent the entities in your world, for example, your Arduino Board and sensors. You can create a Thing using diverse methods.
- From the left hand menu, click .
                To add a Thing, in the top right corner of the web editor, click +
                        New Thing .
A new window opens, labeled New Thing.Figure 1.
 - In the dialog, enter the Thing name as Arduino and add a description. Select the Category Arduinos from the Categories drop down menu.
                Click Create.
                The Arduino Thing will be added in the Things tab of AnythingDB.
