Design a Dashboard to Visualize the Data
Note: To visualize data stored in AnythingDB you will first
need to create an App (an App is a set of permissions needed to ensure that the
access to data is secure and that the user is authorized to perform the
request).
Click Access Control > Apps and create a new App by following these steps.
Add the policy resource of your App and Save it. By adding #, access to all the
resources will be granted.
Note: The Application Client ID and Secret ID is required in configuring the New Workbook in Real time Visualization module. Be sure to capture and save this information.
Figure 3. -
Click Real Time Visualization > Workbooks to create visualizations to understand your data.
Workbooks contain the following sections:
- My Workspace: Dashboards developed by you
- Users: Dashboards other users have shared with you
Figure 4. -
Click New Workbook, name it and click
Create.
Figure 5. - Choose the type of Data Table you want to add. Use SmartWorks to retrieve the data stored in AnythingDB Beta.
Enter the following:
- Client ID: from the app created earlier
- Client Secret: from the app created earlier
- Grant Type: type of app created earlier. Here we use client_credentials.
- Scope: from the app created- thing
- URL: to make the request.
- To retrieve the properties history of a Thing
https://api.swx.altairone.com/beta/spaces/YourSpaceID/things/YourThingUID/properties-history
- Record path: Choose data
Figure 6. -
Click Generate Columns, and then click
Refresh Preview.
The columns are populated and the requested data is displayed.
- Click Save.
- Click Back to return to the Edit Dashboard view.
On the blank canvas (right half section), sketch a simple square by clicking
and dragging on the blank interface. This enables the Visualization menu.
Figure 7. - Select the Visualization mode and configure it using the Visualization settings. Detailed information regarding Data Tables is available from the Panopticon Designer documentation.
