Create a Dashboard Using the SmartWorks Iot Connector
This connector enables you to retrieve the data stored in AnythingDB.
Important: To visualize data stored at the Raw History section in
AnythingDB, or the data stored in a collection, you will first need to create an
app. If not, skip Step 1 and begin at Step 2.
Click Access Control > Apps and create a new App by following these steps.
Note: The Application Client ID and Secret ID is required in configuring the New Workbook in Real time Vizualization module. Be sure to capture and save this information.Note: The App should have Data or Thing as Scopes (depending if you want to get the data stored at the raw history section or the data in a collection) and the type set as Client Credentials.
- Click Real Time Visualization > Workbooks.
Select a folder to work in. By default a root folder with your username has
been created. Right click to see the different operations you can perform.
Figure 1. - Click New Workbook.
Enter a name for the Workbook and click Create.
Figure 2. -
Create a Data Table by clicking the + icon.
Data tables define the queries and source data repository definitions, in order to retrieve data.
Figure 3. -
Under Data Table Settings, enter a title and click the check mark to save it.
Enter a description, if desired.
Figure 4. -
With Data Sources highlighted, under File/URL, select SmartWorks
IoT.
Figure 5. -
Enter the following:
- Client ID: from the app created in Step 1
- Client Secret: from the app created in Step 1
- Grant Type: type of app created in Step 1. Here we use client_credentials.
- Scope: from the app created. Choose thing if you want to retrieve the Thing status of a collection, and data if you want to retrieve the data stored at the Raw History section.
- URL: to make the request.
- If you want to retrieve the things status of a collection: https://api.swx.altairone.com/spaces/YourSpaceID/collections/YourCollectionName/things-status
- If you want to retrieve the data stored at the raw history section for different things: https://api.swx.altairone.com/spaces/YourSpaceID/data/?source[]=FirstThingUID&source[]=SecondThingUID
- Record path: Choose data to retrieve the Thing status of a collection the data stored at the Raw History section.
Figure 6. -
Click Generate Columns, and then click
Refresh Preview.
The columns are populated and the requested data is displayed.
- Click Save.
Click Back to return to the Edit Dashboard view.
Figure 7. -
On the blank canvas (right half section), sketch a simple square by clicking
and dragging on the blank interface.
This enables the Visualization menu.
Select the Visualization mode and configure it using the Visualization
settings.
Detailed information regarding Data Tables is available from the Panopticon Designer documentation.
