Function Log
The Function Log allows you to retrieve the logs from your Functions.
  1. Choose one of the existing Functions, and if desired, enter a date range to filter. The logs from the specified time frame are displayed.
    Note: Use the Search bar and Filter field to adjust the logs that display.
  2. To display the logs for multiple Functions, minimize the current view and repeat the process.
