Send Data to SmartWorks
  1. If you haven’t already, make sure to download the user input and dashboard Python template files..
  2. In Visual Studio Code, add the following:
    1. In the credentials func.cpp file, define the following variable: const char* server found in main invoke function.
    2. In the humidity.cpp file, define the following variables: DHTPIN and DHTTYPE.
    3. In the main.cpp file, define the following variables in the DEFINE GLOBAL VARS section: publishHumidityTopicSTR, publishHumidityTopic dataSTR, and subscribeTopic_STR.
  3. Compile the code and upload to the microcontroller or ESP32 in this case.
  4. Check that the data is being sent to the Raw History section of your Thing.
