This tutorial will guide you through the process of connecting a device (a Lamp) to the SmartWorks IoT platform and
sending data to store it and implement simple business logic.
This tutorial is designed to guide you through setting up a microcontroller (ESP32) to send data to SmartWorks and
have SmartWorks interact with apps designed by the user.
This tutorial will guide you through the process of connecting your computer to the SmartWorks IoT platform and sending
computer resources data such as CPU state, disk usage, latitude, longitude, memory, and memory available to the platform.
You will also learn how to create Actions based on Event Triggers.
This tutorial will guide you through the process of connecting your ESP8266 and DHT10 sensor to the SmartWorks IoT
to control the board LED light and monitor the surrounding humidity.
Stream Processing is a method of tracking and analyzing streams of information of an event, and eventually obtaining useful structured
conclusions out of that raw information.
SmartWorks IoTEdgeOps is a set of tools for building, maintaining and continuously improving code in resource constrained devices at the
edge of smart product ecosystems.
