Manage Your Spaces
You can create multiple Spaces, and toggle between them as
necessary. To create more Spaces or access previously
created Spaces, click Switch Space
at the bottom of the menu pane.
Create a new Space as described in Create Your First Space. -
You can view your Space's details by clicking on the
on the Space tile. It will give you information about how the Space is used.
Figure 1. -
You can edit the Space's name and color to better organize
your project. From the left pane, the icon next to the Space name.
Figure 2. -
Enter the new name in the Name field.
Note: You cannot change the ID, just the name that is displayed.
Figure 3. - Enter the user information, and if desired, select a color and click Save.
- Removing unwanted Spaces can help you keep your account organized. To delete a Space, click Delete Space in the upper right hand corner.
