Send kubectl
This section describes the MQTT messages and topics the Management Service handles to perform the "send-kubectl" action. When using AnythingDB in Studio all of this is taken care of within the product.
Sending a Message to the Management Service
status/<space>/collections/cluster/things/<thing-id>/actions/send-kubectl
The message format for publishing is as follows:
"send-kubectl": {
"input": {
"correlationId": "{create-a-unique-id-for-each-message}",
"command": "kubectl",
"arguments": [
"{each}",
"{new}",
"{argument}",
"{needs}",
"{its}",
"{own}",
"{array}",
"{entry}"
"status": "pending",
"timeRequested": "<datetime>",
"href": "/spaces/<space>/collections/cluster/things/<thing-id>/actions/send-kubectl/<action-id>"
For example:
"send-kubectl": {
"input": {
"correlationId": "666",
"arguments": [
"get",
"nodes",
"-o",
"wide"
"timeRequested": "2020-05-26 15:37:46+0000",
"href": "/spaces/my-space/collections/cluster/things/my-thing-id/actions/send-kubectl/1234"
It is important that each argument is put in a new array entry. If there is a space in the complete command then that means a new argument.
Status Update After Receiving Action Request
Message:
"send-kubectl": {
"href": "/spaces/<space>/collections/cluster/things/<thing-id>/actions/send-kubectl/<action-id>",
"status": "received"
Event Publish After Running Action
/spaces/<space>/collections/cluster/things/<thing-id>/events
Message:
"kubectl-logs": {
"data": {
"correlationId": "{the-unique-id-from-the-request}",
"statusCode": "{an-http-status-code}",
"statusMessage": "{optional descriptive message}",
"response": "{the output in plain text format}"
Example:
"kubectl-logs": {
"data": {
"statusCode": 200,
"statusMessage": "Command executed successfully",
"response": "NAME STATUS ROLES AGE VERSION INTERNAL-IP EXTERNAL-IP OS-IMAGE KERNEL-VERSION CONTAINER-RUNTIME\nmartin-ag150 Ready master 50d v1.18.2+k3s1 10.10.10.100 \u003cnone\u003e Ubuntu 20.04 LTS 5.4.0-40-generic containerd://1.3.3-k3s2\n"
You need to use the correlationId
to match the response to the
request.
Status Update After Completing Action
Message:
"send-kubectl": {
"status": "completed"
