Asset Thing Details in AnythingDB
Each Asset record in AnythingDB has a few preconfigured actions which you can use to control and configure your Asset remotely.
The following actions are defined automatically:
Action Description
Run statistics/metrics gathering Start and update the interval to receive the metrics.
Send kubectl Send kubectl commands from SmartWorks IoT
Stop statistics/metrics gathering Stop the reception of metrics.
Send Kubernetes API Send a RESTful request to the Kubernetes API server running on the Cluster.
Note: The Management Service publishes metrics for the Nodes and Deployments of the Cluster at a regular interval (default: 30 seconds). This data is obtained from the Kubernetes Metrics Server which is installed by default in a K3s installation. The published data can be accessed on the Raw History pane.
If an Action has a red settings icon and a greyed out Run button, then the Action needs to have parameters filled in before it can be executed. Click on the Settings icon to display the form.
When running an Action, the status updates for the Action are shown below the form. The final results of the Action are set up as an Event.
