Action: Send kubernetes API
Available Endpoints
API calls to the Kubernetes API server at the edge cluster can be made using the Send Kubernetes API action.
The form fields show the following parameters: CorrelationId, RequestMethod, Href, and RequestBody. This is a RESTful API.
The CorrelationId is any alphanumeric text string specified by the user in order to match the resulting Event message to the originating Action.
Implemented kubernetes API endpoints are a subset of https://kubernetes.io/docs/reference/generated/kubernetes-api/v1.18/
Currently Available
GET /api/v1/namespaces/{namespace}/pods/{name}/status
GET /api/v1/namespaces/{namespace}/services/{name}/status
GET /api/v1/namespaces/{namespace}/configmaps/{name}
GET /api/v1/namespaces/{namespace}/secrets/{name}
GET /api/v1/namespaces/{namespace}/serviceaccounts/{name}
GET /api/v1/namespaces/{name}/status
GET /api/v1/nodes/{name}/status
PATCH /api/v1/namespaces/{namespace}/pods/{name}/status
PATCH /api/v1/namespaces/{namespace}/services/{name}/status
PATCH /api/v1/namespaces/{namespace}/configmaps/{name}
PATCH /api/v1/namespaces/{namespace}/secrets/{name}
PATCH /api/v1/namespaces/{namespace}/serviceaccounts/{name}
PATCH /api/v1/namespaces/{name}
PATCH /api/v1/nodes/{name}/status
PUT /api/v1/namespaces/{namespace}/pods/{name}/status
PUT /api/v1/namespaces/{namespace}/services/{name}/status
PUT /api/v1/namespaces/{namespace}/configmaps/{name}
PUT /api/v1/namespaces/{namespace}/secrets/{name}
PUT /api/v1/namespaces/{namespace}/serviceaccounts/{name}
PUT /api/v1/namespaces/{name}
PUT /api/v1/nodes/{name}/status
DELETE /api/v1/namespaces/{namespace}/configmaps/{name}
DELETE /api/v1/namespaces/{namespace}/pods/{name}
DELETE /api/v1/namespaces/{namespace}/secrets/{name}
DELETE /api/v1/namespaces/{namespace}/serviceaccounts/{name}
DELETE /api/v1/namespaces/{namespace}/services/{name}
DELETE /api/v1/namespaces/{name}
DELETE /api/v1/nodes/{name}
POST /api/v1/namespaces/{namespace}/configmaps
POST /api/v1/namespaces/{namespace}/pods
POST /api/v1/namespaces/{namespace}/secrets
POST /api/v1/namespaces/{namespace}/serviceaccounts
POST /api/v1/namespaces/{namespace}/services
GET /api/v1/configmaps
GET /api/v1/nodes
GET /api/v1/pods
GET /api/v1/secrets
GET /api/v1/serviceaccounts
GET /api/v1/services
GET /apis/apps/v1/namespaces/{namespace}/deployments/{name}/status
PATCH /apis/apps/v1/namespaces/{namespace}/deployments/{name}/status
PUT /apis/apps/v1/namespaces/{namespace}/deployments/{name}/status
DELETE /apis/apps/v1/namespaces/{namespace}/deployments/{name}
POST /apis/apps/v1/namespaces/{namespace}/deployments
GET /apis/apps/v1/deployments
GET /apis/rbac.authorization.k8s.io/v1/clusterroles/{name}
GET /apis/rbac.authorization.k8s.io/v1/clusterrolebindings/{name}
GET /apis/rbac.authorization.k8s.io/v1/namespaces/{namespace}/roles/{name}
GET /apis/rbac.authorization.k8s.io/v1/namespaces/{namespace}/rolebindings/{name}
PATCH /apis/rbac.authorization.k8s.io/v1/clusterroles/{name}
PATCH /apis/rbac.authorization.k8s.io/v1/clusterrolebindings/{name}
PATCH /apis/rbac.authorization.k8s.io/v1/namespaces/{namespace}/roles/{name}
PATCH /apis/rbac.authorization.k8s.io/v1/namespaces/{namespace}/rolebindings/{name}
PUT /apis/rbac.authorization.k8s.io/v1/clusterroles/{name}
PUT /apis/rbac.authorization.k8s.io/v1/clusterrolebindings/{name}
PUT /apis/rbac.authorization.k8s.io/v1/namespaces/{namespace}/roles/{name}
PUT /apis/rbac.authorization.k8s.io/v1/namespaces/{namespace}/rolebindings/{name}
DELETE /apis/rbac.authorization.k8s.io/v1/clusterroles/{name}
DELETE /apis/rbac.authorization.k8s.io/v1/clusterrolebindings/{name}
DELETE /apis/rbac.authorization.k8s.io/v1/namespaces/{namespace}/roles/{name}
DELETE /apis/rbac.authorization.k8s.io/v1/namespaces/{namespace}/rolebindings/{name}
GET /apis/rbac.authorization.k8s.io/v1/roles
GET /apis/rbac.authorization.k8s.io/v1/rolebindings
POST /apis/rbac.authorization.k8s.io/v1/clusterroles
POST /apis/rbac.authorization.k8s.io/v1/clusterrolebindings
POST /apis/rbac.authorization.k8s.io/v1/namespaces/{namespace}/roles
POST /apis/rbac.authorization.k8s.io/v1/namespaces/{namespace}/rolebindings
Custom
GET /apis/swx/v1/edge-apps
POST /apis/swx/v1/edge-apps
GET /apis/swx/v1/edge-apps/{edge-app-id}
PUT /apis/swx/v1/edge-apps/{edge-app-id}
DELETE /apis/swx/v1/edge-apps/{edge-app-id}
PUT /apis/swx/v1/apply
Request Body
The custom API endpoint is the equivalent of "kubectl apply" and accepts a URL as the request body or the actual yaml (string).
The other endpoints use JSON (stringified).
See the kubernetes reference documentation for details.
