AnythingDB Beta
Altair SmartWorks IoT AnythingDB beta enables you to create digital models of the assets that define your smart connected ecosystem.
Overview
AnythingDB beta is a flexible, secure database that enables you to create a digital model for a smart connected ecosystem.
It helps capture and access metadata for devices, processes, users, tasks, or any other entity considered in your application.
AnythingDB beta follows the Web of Things (WoT) standards defined by the World Wide Web Consortium (W3C) for the interoperability of different IoT platforms and application domains.
AnythingDB beta contains following features:
- Every Thing: enables you to define the entities in the smart connected ecosystem
- Models: templates to ease the process of defining new Things
- Structure: group your Assets (Things) in a logical way and define relations between them
- Custom Queries: perform custom queries in your database
Comparison from the Original AnythingDB
Main changes from the previous DB:
- Things
- No longer need to belong to Categories
- Models
- Belong to the Space, not to specific Categories
- Categories
- Can be defined:
- Without a Model assigned: you can group Things with different schemas
- With a Model assigned: you can group Things with the same Model but different Versions of this Model
- With a Model and a specific Version assigned: you can group Things with a specific Model and Version
