Create a Deployment
In order to deploy an Edge Application to an Asset, a Deployment needs to be created first. The Deployment contains the values to use for the override parameters defined on the Resource templates of the Edge Application.
Click on the Deployments button on the Edge App details
pane to see the list of Deployments.
If there are no Deployments yet, the New Deployment Form is automatically displayed.Figure 2.
The minimum requirement for a Deployment is a name. Any override parameter for which the value is left blank will use the default defined in the Resource template.
If Deployments already exists, a new one can be created by clicking on the
+ New Deployment button.
Figure 3.
